11-24-2007, 08:42 AM #1
- Jun 2005
- 42
washable hogshair vs disposable fiberglass
Which has a higher MERV rating?
Saw a washable hogshair filter that claimed MERV 4 (would not have thought it was that high) and was wondering if washable hogshair provided more filtration than disposable fiberglass which does not give a MERV.
11-24-2007, 09:04 AM #2
- Feb 2003
- Huntsville,AL
- 4,125
both are poor filters!
strive to get to 4inch thick pleated = getting ducts to proper performance levels
fiberglass probably= 2 MERV
better change/ wash ea 2 weeks
if coated, too long between maintenance eventsharvest rainwater,make SHADE,R75/50/30= roof/wall/floor, use HVAC mastic,caulk all wall seams!
11-24-2007, 09:25 AM #3
if you can sprinkle salt on a filter and it can pass through it you dont wont it.
especially for heatpumps or central airI dont warranty Tinkeritus
11-24-2007, 10:10 AM #4
- Jun 2007
- The Twilight Zone
- 2,964
I use NaturalAire Standard pleated filters, MERV 8, made by Flanders. A 3-pack from Home Depot is $7.
Good luck.
11-24-2007, 12:37 PM #5
- Jun 2005
- The Gray Northwest
- 661
Hogshair works great for large particulate like over-spray in paint booths. Fiberglass has a slightly higher merv rating but has a lower holding capacity than hogshair. Even a "cheapo" pleated fiflter does a better job for your application.
