Thread: Wall Furnance
    Nov 2007
    Wall Furnance
    Wanted some expert advice. We have a wall mounted gas furnace (40 year old) which directly vents (intake/outtake) outside that just stopped working. This heaters, is in addition to our regular hot water baseboard heat. Works great as we can just heat the room without heating the entire bottom floor.
    My local plumber thinks that the wall mounted furnace is not complaint to local codes, as it about 2 feet from the windows in our family room (something about carbon monoxide coming in). Is that true? We live in Chelmsford, MA.
    Do you have any good recommendation from a wall furnace which is direct vent. We currently have a dynavent sa 40 system.
    Jeff
    Dec 2001
    Chicago, N/W burbs
    have it checked by a local professional hvac tech.
    Those old dynavent units were pretty sturdy.
    If it's working well and the heat exchanger is intact then you're probably OK.
    R2B4BTU
    SE Michigan
    You can still get parts for that...allthough I think dynavent is under a different name now.
    http://67.114.233.34/cgi-bin/lansawe...CIFCI(A0030):8
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Nov 2007
    But is it within building code
    Thanks for your responses.
    1) But is it within building code to keep it within 2feet of windows?
    2) Also the problem with the furnace I think is the gas valve. I know there is gas coming in. The glo lamp turns on, I hear clicking, the fan turns on, but no heat. Do you guys think it is the gas valve.?
    Again thanks for the response.
    Jeff
    Quote Originally Posted by coolwhip View Post
    Dec 2001
    Chicago, N/W burbs
    I can steer you in the right direction to diagnose the problem.
    This site, however, is a site for members of the trade.
    We will not dispense information that may or may not help you.
    You really should call a qualified service technician to deal wit this problem.
    R2B4BTU
    Dec 2001
    Chicago, N/W burbs
    thread closed
    R2B4BTU
