    Oct 2002
    Ontario East
    propane plus 90+ furnace = bad?
    This came up during a fireplace discussion...
    "Sound like a newer furnace you have their otter , Most gas furnaces have metal inshot burners that rust out from the propane fuel . Doesnt happen on natural but Id do a simple magnet check to see if their metal or stainless . Mostt he time the flames look bad on propane and its rusty burners . Another sign is a small dusting of rust under the front of the burners . Might need a mirror or ask your tech while hes there if they are ss or metal burners . Just another heads up on the problems with propane to watch for ."
    Goodman GMH95, with propane conversion kit, first winter.
    Opinions? Is this one more thing to worry about?
    Toledo, Ohio, United States
    Twilli say not to worry, put your worries on global warming.
    No Heat No Cool You need Action Fast
    Oct 2002
    Ontario East
    Quote Originally Posted by twilli3967 View Post
    Otter not worried about global warming. Otter is worried about good stuff being sacrificed to keep the tree huggers happy.
    And the monster under his bed, is that you, Hillary?
    leland nc
    i would use the mirra to heep en eye on that monster hillory under ya bed
    the burners will be ok as long as it is set up properly and serviced regulary
    also have the pressure coming into you house check twice a years spring and late fall. Propane is temp sensative
    the pressure can drop in the cold and cause you to use more then in the warm weather
