Results 1 to 2 of 2
Thread: Hey!
    Nov 2007
    Hey!
    I never ask for a DIY BOB! I asked what activates a switch!
    Quote Originally Posted by MUMM RA View Post
    My furnace wasn't working and i ended up taking the oil ignition control box apart. It looks like theres a magnetic switch in there.
    my question is, whats makes that switch activate? If i push it over with a clamp everything works fine, house gets warm and i just have to take the clamp off to make it stop. it still runs for a few minutes though.
    could my thermostat be bad. if i remember correctly it used to have a little spark when i turned the dial to a warmer temp. Now there isn't a spark.
    I know this probably ain't safe. any help?
    Last edited by HeyBob; 11-21-2007 at 09:54 AM. Reason: Removed Link to another HVAC Site with a forum, link was originally a pic that showed up when original post was quoted.
    Howell, Michigan
    MUMM RA,
    By answering your question constitutes DIY help in the rules. Also the reason I closed the thread is because there are a lot of guys here that just might jump in and start giving DIY advice regardless.
    That is a primary oil burner safety control, it is potentially dangerous to bypass it and/or take it apart and attempt to repair it.
    The best help that we can offer you here is for you to contact a service company that has technicians experienced with oil fired equipment.
    Respectfully,
    Bob
