Results 1 to 10 of 10
    Nov 2007
    Thermostat - which to get Honeywell vs. Trane
    My system will most like consist of:
    Trane XV80 furnace
    Trane XL14i AC/Heat Pump
    My question is which thermostat should I use for this system? I only want to consider 7 day touch screens. The ones below seem like the exact same unit.
    Honeywell TH8320 VisionPRO
    Trane TCONT802 XL800 Series
    Any advice is appreciated.
    Thanks,
    K
    They are the same basic T-stat
    Trane dumbed down the 8320 best I remember.
    is there any package $$$ difference from the contractor?
    If you are getting a heat pump, get the IAQ version so you can stage the gas furnace. The 8320/802 cannot.
    May 2005
    Wilmington, NC
    Trane's TCONT803AS32DA tstat. It was designed for that system.
    I had the same system installed this summer and as a result of conversations on this board, I chose the Vision Pro IAQ
    Nice TStat and it will do a good job with that system should you decide to go with it
    Mike
    Dec 2006
    Middle Tennessee
    as already stated IAQ!
    New Hampshire
    I'll wager the trane T/Stat is a honeywell with the face changed .
    Nov 2007
    Thanks for all the input.
    I can not believe the price difference the contractor quoted vs. the market rate for an IAQ T/Stat. There should be N/C to install a t-stat if they are installing a new furnace and Heat Pump so this should not be factored in the price of the thermostat.
    I understand that the contractor needs to make money but highway robbery is another story. I guess I will be making some calls and getting 4-5 quotes using similar equipment (Trane/American Standard) before I decide to pull the trigger on the new system.
    Thanks again and if you have anything to add or suggest please do so.
    K
    The 803 is a TH8321.
    No dehumidify on demand, no staging of gas furnace if dual fuel, no backup if dual fuel... compared to IAQ. Many other features lost.
    Rochester, MN
    Spend the money for the IAQ. Best t-stat out there for this type of set up.. You'll be glad you did.
    I know I am happy with mine!
