    Nov 2007
    expansion tank location
    I have A cast iron boiler with pump on return side of system and bladder type
    tank before that, with spiro vent. is this ok? i Know it suggested that tanks be close to suction side of pump, but should there be room for expansion on supply side?
    Nov 2007
    Chicago
    It is a closed system, so you just need to account for the expansion. You place the expansion tank on the suction side of the pump because that is where the lowest pressure is expected in the system. At the lowest pressure, the most air will come out of solution. That is why the air seperator or vent is placed there.
    Nov 2007
    thank you. I guess most of the piping diagrams I have seen show pump and tank on supply side of boiler. I know many prefer this set up, any thoughts on that?
    Jun 2000
    N. W., IN
    Spiro., tank, feed, pump all on supply works best.
    Jun 2006
    Richmond, VA
    Quote Originally Posted by Ron View Post
    I don't work on very many, but why is it better on the supply side?
    I wish I had a $1.00 for every response I deleted.....
    "Decidedly Superior in a twisted pathetic way".....
    Nov 2007
    Chicago
    It is better on the supply side so you get the highest temperature along with the lowest pressure for air removal.
