    Nov 2007
    carrier 96 furnace
    Is there any way to make the evolution system run on high fan when my steam humidifier is working? RB
    PA/DE area
    Infinity control can be put to high speed at control
    It's NOT the BRAND,it's the company that installs it!!!!!
    Nov 2007
    Control
    I put it on high and after a while it backed off. Is thee any way to only run full time on high when the skuttle stainless steel steam heater is on? They recommend I not rut it without doing this.
    Feb 2005
    Richmond
    Do you have programable fan enabled? You can set it to run on High all the time if you do. Remember, speed will change when it calls for heat, and at 1:00 PM, when it checks for static pressure.
