Thread: New coil
    Nov 2007
    New coil
    I have an inquiry I hope you can help me with. If a new coil is ordered from one of the HVAC companies, should the coil be pressurized with Nitrogen? I could understand the tube ends being plugged to avoid entry of dirt, but if the coil isn't filled with Nitrogen, would there really be a problem with corrosion?
    Nov 2000
    Eastern PA
    A new coil should be charged with some inert gas to prevent having moisture in it from the atmosphere.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Monmouth Junction-NJ-USA
    How can you be New and Improved at the same time. You are either new or you are improved.??????? Not sure if I believe that you are either. LOL..How you been?????
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    Most replacement coils are shipped with a holding charge of Nitrogen these days, to prevent air and noncondensibles for entering the coil, and to verify the coil does not leak prior to installation.
    Nov 2007
    Gentlemen,
    Thanks for your input as to the reasons for charging coils woth Nitrogen.
