Page 3 of 3 FirstFirst 123
Results 27 to 32 of 32
Thread: rack flooding
  1. #27
    Nov 2007
    State College, Pa.
    A tripped oil safety switch doesn't necessarily indicate a flood back problem. A single phase condition, caused by either a power failure, or burned contacts on the compressor contactors could also cause your oss to trip. I suspect this was a gradual condition, ocuring over several days. if the system is computer driven, you may be able to access the history logs to help you determine what happened.
    remember, no good deed goes unpunished
  2. #28
    Jan 2006
    DFW Metroplex
    Quote Originally Posted by fuzzyj View Post
    Good point.
    I took it as a given the oil trips were in fact due to liquid floodback.
    Can't assume anything really, can we?
  3. #29
    check the superheat on all txv checked all cases for no floodback due to clogged drain bad defrost heaters etc
    next check to make sure the superheat is set correctly on compressors copeland recommend 13 degrees at compressor
  4. #30
    Jan 2006
    DFW Metroplex
    Quote Originally Posted by daygotech View Post
    Has it changed???
    I thought it was always no less than +20F and no more than +40F at the compressor.
  5. #31
    Jul 2005
    FLORIDA
    thats way low for a rack system at the suction service valve brother
    need to pull out the AE book and get the proper superheat at the compressor but the starting point is the evap and then the compressor and if its line then all is good if not piping is a problem
    once you think you've seen it all
    (THINK AGAIN)
    I would rather work for free than be look upon as a thief!!!!!
  6. #32
    Jun 2001
    Michigan
    18 days ago guys. Old news.
