Results 14 to 26 of 32
Thread: rack flooding
11-23-2007, 11:42 AM #14
Rack flooding
Hey jaybee whats the 411 on this?
11-23-2007, 03:57 PM #15I love the smell of phosgene first thing in the morning:
Educational forums are open.
11-23-2007, 08:01 PM #16
- Apr 2003
- New York
- 668
Well didnot go back . An jorneyman did and when I ask did he find the floodback he had no answer. As far as i know it came in again and all the person did was get the rack going . Well, if i have to go back i got good info to go back with . So the 411 is it's an unresolved issue, but then again im just a dumb appr.
11-23-2007, 08:34 PM #17
ice, or frost automatically doesn't mean flooding.
"The only real security that a man can have in this world is a reserve of knowledge, experience and ability." Henry Ford
11-23-2007, 09:00 PM #18
- Apr 2003
- New York
- 668
well it might meduim temp system,iced up compressors common suction, 4 of five compressors are off on ofc and there is refrigerent visible in sightglass at the crankcase call has came back 2 times ,again just a guess didnt measure superheat at the comp.
11-24-2007, 07:35 AM #19I love the smell of phosgene first thing in the morning:
11-24-2007, 07:44 AM #20
jaybee is this a loop system ? ie commom suction and a common liq feeding
many cases. or is a single system feed?I love the smell of phosgene first thing in the morning:
11-24-2007, 12:43 PM #21
Professional Member*
- Jun 2005
- Las Vegas NV
- 1,111
11-24-2007, 12:56 PM #22I love the smell of phosgene first thing in the morning:
11-24-2007, 02:02 PM #23
11-24-2007, 08:55 PM #24
- Jun 2005
- Las Vegas NV
- 1,111
12-01-2007, 12:53 PM #25
If your rack flooding out as bad as it sounds like it is............this shouldn't be too terribly hard to pinpoint.
My first guess would be a check valve failed (assuming gas defrost) or a heat exchanger cracked internally.
A fully open TXV will cause problems on a single compressor system but on a rack with a suction accumulator I haven't seen a single TXV wipe out a compressor yet...........not saying that it CAN'T happen.........just sayin'
12-01-2007, 02:25 PM #26
I had a rack about 8-9 years ago wash out the oil starting on a weekend duty weekend. Hussmann Super Plus
Would go to the store , pump out every thing , spend 2-3 hours and could find nothing.
This happened 3 times in one wekend.
Eventually found the heat reclaim 3-way valve pumpout line had been replaced with the 3-way valve 2 months before and had not needed heat pretty much since the install.
That weekend , the weather was changing so the heat was cycling.
When we'd show up the store was calling for heat so everything was fine.
The suction lines were fine at the header and any circuit close to cold we'd dig into the valves , but never really found anything.
When heat satisfied,the pumpout would flood like a sum*****.
The guy that did the 3-way valve upsized the pumpout from 1/4 to 3/8.
He was the only guy that knew this.
I think we cut in a section of 1/8" tubing to meter the pumpout.
Problem solved
That was a curve ball...
what's wrong with that plenty of sub cooling.
