Results 14 to 22 of 22
    Nov 2007
    is 12.60 a pretty good EER rating?
    DC Metro Area (MD)
    Quote Originally Posted by Kevenater View Post
    Yes, I would consider that very good. What combination is giving that? If you look at a good number of combinations, you'll find them to be lower than 12 actually.
    Tidewater Virginia
    I live in Virgina along a river. I have an 19I Infinity with 2 stage compressor and var air handler. Mine is a 3 ton serving 1600 sq ft. It handled the humdity fine with the default setting of 45%. This is adjustable with the Infinity.
    Nov 2007
    So the lower the EER the better? I thought the higher the better. It's a carrier infinity 16 model 25hna636a30, fan coil is FE4ANB006+Ul. not sure what the UL stands for, only 3 of their fan coils have this on the end of the model number. the seer is 16.50 eer is 12.60, hspf is 9.0
    Apr 2004
    No the higher the EER the better. That is pretty good there.
    Im not sure off hand What UL (in this case) stands for, but the + sign means you have to use that air handler and add a "UL". The product data will tell you what this means or one of the Carrier guys can tell you. You should know that if you dont add it, the efficiency ratings will likely go down. How much requires further investigation. Adding some devices to get effeiciency can sacrafice comfort. Not knowing what a UL is, I wouldnt make that a blanket statement.
    Apr 2004
    update... Here is the Product Data.... FYI. I dont see it requiring a UL in there.
    http://www.xpedio.carrier.com/idc/gr...e=PdfHighlight
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by OlManRivah View Post
    Just curious, how much fresh air ventilation do you bring into your home and how do you do it? Also how many occupants? Crawlspace or basement? ASHRAE recommends 50-75 cfm of fresh air ventilation to purge indoor pollutants and renew oxygen. I would expect 70-80 lbs. per day of moisture load. Eliminating the fresh air ventilation/infiltration makes humidity control easier.
    With low occupancy, air tight construction, long wet, cool stretches, and no fresh air ventilation, maintaining low humidity is possible with the more complex a/cs. With supplemental dehumidification, it's possible to have fresh air ventilation during wet cool weather without making your home damp. Regards TB
    Nov 2007
    i talked to my installer and he didnt know the exact model fan coil he priced me, he's gettin back to me on it, but the model i listed above, is $2,700 higher !!!!!!!!! for the exact same thing, only a diff model(5ton) fan coil!!!!!!!!! I guess the one I'm gettin is a 3 ton....like my hp will be. my info came from the ARI Directory page somebody told me to go to up above.
    Tidewater Virginia
    Quote Originally Posted by teddy bear View Post
    Not a real tight home with no additional ventilation. Mostly just the 2 of us. It's a rancher with crawlspace. During the heating season it get's a little dry since we don't run a humidifier.
