    Nov 2007
    Rathdrum, Idaho
    Trane Product Data
    I'm trying to find a link to download Trane Product Data for the following items:
    XL14i Heat Pump (2TWX4042B1000AA)
    XR 90 Furnace (TDX1B080A9421A)
    Indoor Coil(?) 2TXC8048AC3HCAA
    Have downloaded an XL14i Product Data for a 4TTX4018 HP but I'm trying to get exact if I can.
    Thank you.
    -OKJ
    SW FL
    Thumbs up
    Quote Originally Posted by speedymonk View Post
    Thank you. -OKJ
    Some split systems can be found at
    http://www.trane.com/Commercial/Prod...st.aspx?i=1264
    Discuss equipment selections with local dealer.
    I doubt that a furnace would be required in Washington state.
    I know it very rarely ( < 250 hours annually) goes below freezing in Olympia.
    66 hours < 25'F
    ++++++ Tacoma
    'F Annual
    100 …
    95 …
    90 … 9
    85 … 35
    80 … 87
    75 … 173
    70 … 311
    65 … 498
    60 … 801
    55 … 1159
    50 … 1424
    45 … 1447
    40 … 1259
    35 … 835
    30 … 482
    25 … 169
    20 … 45
    15 … 15
    10 … 6
    5 …
    0 …
    Designer Dan
    Mar 2006
    The South
    Speedy
    A gas furnace used as backup is overkill for your area/climate. Unless you are using gas for other reasons such as cooking,water heating, etc or just want that heating source as backup, then you should consider the 80% AFUE XV80 var speed model. And I would not purchase an air handler or gas furnace as backup without a var speed blower.
    IMO
    Upstate SC
    Check out this site - I found it once on the net when I was looking for info for my system. I can't vouch for the authenticity of the documents or whether they are most current.
    http://www.aireng.com/clientuploads/
