    Nov 2007
    17 Degree Capacity Goes South When HSPF Goes North
    Anyone understand why? If you peruse the aridirectory.org HP database you
    can't help notice that the ARI 17 degree values move inversly to the HSPF
    figure of merit. It looks like ECM fans and oversize coils are used to jack up
    both SEER and HSPF so could it be the case that the oversize coils drop in
    efficiency faster as the outdoor temp drops?
    Mar 2006
    Delaware
    Got a link to that site showing this data? In my experience the two stage high HSPF units do pretty well at low temps. The inverter minisplits do REALLY well at low temps!
    Quote Originally Posted by hivacjack View Post
    Nov 2007
    Jun 2007
    Metro St. Louis
    What's wrong with a 4-ton 2-stage HP rated at 9.75 HSPF and 34K BTU at 17*.
    Nov 2007
    Quote Originally Posted by Waterloo View Post
    stay within the same capacity to make the comparison. i.e. compare 3Ton single stage
    to 3Ton single stage. There aren't many 2 stage HP's which have a lower HSPF version
    in the product line. For example compare the ssz14 goodman's with the ssz16 goodman's.
    give us some data
    Can you insert some of the data from ARI to look at the model numbers? I don't see the phenomenon you are talking about.
