Results 1 to 2 of 2
    Bryant package unit error code
    I have a Bryant package unit and the fan tuns on but the gas does not ignite. no heat. i took off the cover and there is a red led light that flashes 6 times pauses and repeats. with thermostat in off position light stay lit. Is there a guide anywhere that lists error codes for my unit (if in fact that is an error code). any help would be greatly appreciated. i'm hoping the code will tell me the component that is causing the malfunction so i can replace that part. Thank you for any help
    Model number is 5BBANW036080ACAF
    Serial number is 3697G10449
    The site rules state that no DIY info will be given on this site, and you stated even in your post that you will then replace the part yourself.
    Thread closed.
