    Nov 2007
    Confused Gas Burner Cycling
    I Have A Janitrol Hi-eff Mod# Gdp075-3 Installed New In 1990. The Burners Cycle Up And Down Rapidly While Starting The Heating Cycle. The Pilot Light Is Steady On The Flame Sensor Wire While This Is Occurring. It Happens Sporadically, But When It Does You Can Hear The Static From Contacts Opening And Closing In My Computer Speakers. Believe It Or Not, That Is How I Discovered The Problem.
    Any Ideas? Thanks For Your Help.
    Chicago area
    Is the gas valve loosing power? If so find out where the signal is cutting out. If this model has a smartvalve, then that is likely the issue. They have problems with the internal solder joints.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by Dmaintenanceman View Post
    i am glad it was installed new in 1990
    cause now we know it was new (only) 17 years ago!
    the way you word your question tells me you better hire a qualified hvac co.
    in my lumpy chair
    im sure that theres a professional tech in your area that is close to being layed off that would be happy to service this unit
    no DIYers here call a contractor for service
    Quote Originally Posted by heatingman View Post
    this sight is not here to take food out of the mouths of our familys
    I dont warranty Tinkeritus
    in my lumpy chair
    i know why but im not telling. call a pro
    Nov 2007
    Thanks for the education. Since the last post, some other interesting symptoms came up that I will need to have a more qualified tech look at.
