Results 1 to 13 of 16
    Retrofit system and duct size--do I have to be supper concerned
    We are planning to retrofit or existing system with an infinity gas furnace, infinity A/C unit and new coil in our forced air home that is from the 1930's. My question is: in general do most homes have adequate size ducts to handle such a retrofit or is duct size a major issue. Since my contractor did not spend too much time checking out the duct sizes in our house, I assumed that duct size was in general was not much of an issue--- now I am concerned Worried in Washington dc.Thanks for your reply and sorry for any double posts.
    Duct sizing is a critical issue, and existing duct systems, especially older heating ducts, are rarely even close to adequately sized for the new equipment.
    Ditto,ask about it before the install!They need to look closely,test the existing duct static pressure,etc..
    Other than replacing the ducts what can be done to correct for there size. Also is a static pressure test difficult to do? thanks
    Oct 2007
    Milwaukee,WI
    Quote Originally Posted by ron3637 View Post
    Nothing really.
    It's easy for any professional.
    ___________________________
    Chicago is an indian word for stinky!!!!!!
    -supertek65
    If nothing can be done what is the difference? What would you recommend if the test comes back negative? thanks?
    Something can always be done about it.
    The question is how much will it cost.
    Some times its a simple fix, and some times its not.
    Get your ducts tested/checked first.
    Oct 2007
    Milwaukee,WI
    The only thing that can really be done is to have new ducts put in.
    -supertek65
    Myrtle Beach, SC
    Sometimes bigger ducts is the answer. Sometimes low loss fittings can provide enough improvement.
    We do load calculations, most existing units in my area are too big. The ducts may be too small for your existing system, but if you install a smaller system, the ducts may now be adequate.
    But if you don't test the ducts before the changeout, you are really screwed if you find out they are too small after the changeout. Then you have to do the whole thing over again.
    Remember, Air Conditioning begins with AIR.
    Quote Originally Posted by Lash View Post
    Improved fittings,turning vanes,adding an additional return trunk ,etc.,can often solve high static issues.
    Parallel supply trunks can also solve issues.
    Oct 2007
    Milwaukee,WI
    3 of the 4 things you listed qualify as 'new duct'.
    -supertek65
    "Originally Posted by ron3637
    Nothing really."
    __________________
    Your comment above lead me to believe that you were stating ducts need to be replaced,sorry for my mistake.
    And yes some of what I suggested is adding new ducts and fitting ,just not wholesale replacement of an existing duct system,to solve a static issue.
    If it's anything like my house (built before A/C was invented) then the duct size is adequate for heating, but not for A/C.
