Results 1 to 13 of 21
    New England
    Extended Warranty, Parts/Labor or Parts only?
    Hi - I finally found a local dealer who would offer me a Bryant-backed extended 10yr warranty on my Evolution Furnace, and my Evolution A/C system (i have separate systems, heat in the basement, A/C in the Attic).
    The price for parts was low-hundreds of dollars. I guess it's low because it only covers years 6-10, and only those parts not covered for 10yrs. The price for P/L was significantly (~6-7x) higher - probably because it covers years 2-10?
    anyway, from what I'm reading here, it seems like going for the parts may be worth it - make it back on one repair . Since I have to cover both systems (don't know which will break), going P & L seems rather pricey for the extra benefit, especially as I would expect labor costs to be limited to a couple of hours per repair? (whereas parts costs can be, well, whatever).
    what do you guys think?
    /j
    Do you think it might be possible for labor rates to be 175 or more an hour 5 years from now.
    Find out current labor rate, then decide if the labor warranty is worth it.
    As gasoline prices go up, more companies will be charging a trip/fuel charge, might want to add that possibility in to your decision.
    New England
    Thanks BT - at current labor rates, I'd be prepaying for more than 10 hours of labor across both systems. Even a few years from now that could still be like 3 repairs (the company is only 10 minutes away). Not saying it -wouldn't- pay off (can't prove a negative), but was thinking my chances of making back the parts-only was much better, as I think i might make it back on the first repair.
    /j
    Virginia
    parts and labor warranty also cover freon, welding charges ,nitrogen and other misc charges if 1 of the coil leaks or compressor fails in the next 10 years the p&l warranty will seam like a bargain
    New England
    I thought compressor had 10-year warranty....
    Virginia
    most due but its not going to be changed for free.
    Virginia
    unless it is in the first year
    New England
    well, maybe it's not rational, I can see spending a few hundred to cover the parts, but close to a couple K (both systems) to pre-buy my labor seems tougher - i could invest that sort of money 8-}
    but I'll think about it...
    anyway, wasn't the reason I paid up for Evolution, in part, reliability? 8-}
    /j
    Quote Originally Posted by jeffw_00 View Post
    /j
    If it was that reliable, you wouldn't have to pay for a 10 years parts warranty.
    Put the money in a CD, if your right your ahead of the game.
    Dec 2006
    Middle Tennessee
    and if your wrong CHA-CHING!
    New England
    Quote Originally Posted by Airmechanical View Post
    See - I'm not sure I buy that - I like insuring against some mega-expensive part, but when would labor ever run more than 2-3 hours....
    MN
    heat exchangers and compressors can take awhile, if its a burnout compressor, all day might become an issue. If your a poker playing person, go for the gamble, if your not be safe and pay the extra now. But don't b!tch at the service guy in 6 yrs cause you have to pay the new guy for 5 hrs labor trying to diagnose a intermittent problem he has never seen before. Or change that cmpressor or heat exchanger that he has never changed before.
    You can't fix stupid
    Virginia
    compressor or evaporator coil , compressor failure is rare in a properly installed and maintained system but evap coil leaks are not. here in south Texas ac systems run 9 months a year. You might try to see if there is some wiggle room in the price of the warranty. If it is a couple of k i would skip it.
