Results 14 to 17 of 17
    leland nc
    just slow the blower down so it will be able to remove more humidity while it is running. May need to speed it up for heat mode pressure readings will determin that
    do not put any suppys in garage because it is against all codes i know of because the cieling of the garage will need fire code rock and you will be breaking its rating and also leaving a place for a fire to breath
    returns in garage is bad also because you will draw all offensive odors into the living eara
    A multi zone mini split would be ok.
    Apr 2005
    new jersey
    I would think that for moveing 600 to 800 cfm for the tons. and 5 supplys of 8 " can move over 1000 cfm plus 3 supplys of 6" = 300 cfm. would have v low volocity. I would have ran 7" instead of 8".
    S.W. PA
    no supply or returns here to a garage from a system that conditions any type of living space
    all you are doing is asking for trouble jmho
