Results 14 to 19 of 19
    Sep 2006
    Hmm
    A short radius elbow is equivalent to 10' of 3" pipe. A long radius is equivalent to 6' of 3" pipe. Do you still come up with your 70'?
    Oct 2007
    Mount Gilead, Ohio
    4 long radius 90s figured at 5' each so w/ your formula 74' I have not seen the install yet but im sure im gonna end up w/ this one. Install dept always turns there problems over to service
    Apr 2004
    Quote Originally Posted by tinmantu View Post
    Make sure the vents are correct, then use a magnhelic gauge to test the pressure switch.
    Absolutely.
    I find it hard to believe TRANE is sending a factory guy out without someone at least giving up actual pressure measurements. What is your pressure and what is the switch rated at?
    Look, by pulling the fresh air you actually would decrease the negative pull on the furnace's HX, not improve it. However if your vent is restrictive, you may have hit full blower curve on the inducer indicating something is wrong with either a sag, an obstuction, short sweeping ells, or simply too long. You may also be trying to vent into a head wind.
    Chicago area
    Pipe termination
    Many installers today dont look at instructions. I would guess that if all the piping is new, then the problem is how the piping terminates, IE exaust to close to intake, causing reduced pressure differential to satisfy the pressure switch.
    Nov 2007
    NC
    Is it possible that on the new installation a screen of some sort was added to the end of the flu pipe. I've had a install crew put a screen on that did not allow enough air to flow out and kept kicking out the pressure switch.
    North St Paul MN
    Quote Originally Posted by sandpipertech View Post
    A good point sandpipertech, but if they haven't fixed it by now, theyr'e probably froze to death......this thread is 1 1/2 years old.
    I'd rather have a bottle in front of me, than a frontal lobotomy.
