Results 1 to 13 of 19
    Oct 2007
    Mount Gilead, Ohio
    trane install problem
    installer called me today couldnt get new trane 90% two pipe system to fire. had pressure switch failure. walked him thru a few things and we got it fired by pulling the intake air pipe. dont understand why,both intake and exhaust pipes are new, and each total 70' total length w/90s added into that total. installation manual allows 100'. gonna call trane in the morning but woul like to hear any of your ideas on this
    thanks,
    scott
    Oct 2006
    What size pipe did you use?
    Nov 2007
    NC
    That's what she said
    Oct 2007
    Mount Gilead, Ohio
    3" pipe. h/o had same problem with old furnace. Called trane and they are stumped, they are coming out to look. Ill let you all know what the verdict is
    North St Paul MN
    Was the pipe stored outside prior to install? It could be plugged from birdnest, or debris, and installers didn't notice an obstrution before they put it in.
    I'd rather have a bottle in front of me, than a frontal lobotomy.
    Cincinnati, Ohio
    Quote Originally Posted by in-trane-ing View Post
    Here is a big clue.....I assume you are also using existing pvc flue.
    Nov 2005
    If the old furnace had the same problem it should make it easy to find. It has to be something in the pipe, or the way it was installed.
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    May 2005
    Western Kansas
    Make sure the vents are correct, then use a magnhelic gauge to test the pressure switch. With that length of a run, it may be as simple of a fix as a high altitude pressure switch. I live at around 3000 feet and was having a problem with one during a low pressure storm system. Called Trane and they said I was on the border line, they sent out a different one and it worked. Went back a few days later and just for giggles tried the old one after the system moved out and it worked fine.
    Oct 2006
    Vallejo, CA
    Quote Originally Posted by tinmantu View Post
    DITTO!
    Oct 2007
    Mount Gilead, Ohio
    Quote Originally Posted by markco View Post
    cut pipe to look for obstructions but found none,
    thanks
    Oct 2007
    Mount Gilead, Ohio
    Quote Originally Posted by sinsee View Post
    new pipe
    Oct 2007
    Mount Gilead, Ohio
    never heard of this but something to look into, but not sure if that is it because when they did get it to fire w/ the pipe on the burners wouldnt like right due to starvation of combustion air. I havent heard if Trane has showed up yet to the job. Ill let you all know when I find out
    Thanks again
    Kansas City
    What about running the last third of pipe in 4 inch diamater
    How many 90's? Were they long radius?
