    Grottoes VA
    FYI Fyrite pro 125
    Went to use my Bacharach today, turned it on and pump ran for 5 sec's and shut off, crap.
    Well I took it apart this evening and found the impeller was stuck. I took the impeller apart and cleaned everything with a Qtip and put it all back together. Works like new now.
    Very easy to tear apart and clean just don't lose the impeller blades. There are 3 very small plastic pieces that make up the impeller blades.
    Good to hear, next time mine screws up I'll send it to you.
    Grottoes VA
    You may not want too, I may just keep it.
