    Nov 2007
    help with n.g. baseboard heat system
    we bought a well-mclain h.w. boiler from a friend .he thought he would help me by disconnecting the wiring for me without taking any pics of the wiring. i have some of the wiring right the zone valves work,the t-stats work,the burner comes on and goes off when proper temp is reached,but, the pump comes on and will not shut off at all. it's a taco pump.the boiler is about ten years old,a well-mcclain cg7 ,the relay is a white rogers 829a-832 I may be able to send pics of the system please help i am a master plumber but,i know little about wiring. thank you TOM
    leland nc
    glad you were able to get this far
    dont think it is the relay
    call a pro in to wire it correctly
    Jun 2007
    Minneapolis, MN
    If you are a Master Plumber call Weil McLain or your local distributor for same and have tech services walk you through it. If you haven't the electrical experience remember that electrical components can't be returned.
    MA
    PS. If you smell something bad, you bought a transformer.
