    buzzing noise from Carrier infinity airhandler
    I just had my new system installed yesterday. It is a Carrier 2 stage, 2 ton 16 seer heat pump with infinity air handler and controller. I noticed as the air handler starts, there is this low pitch buzzing sound from the unit. It almost sounds like a refrigerator. Is this normal? Unfortunately, the system is installed inside a bed room and the noise can drive u crazy.. any suggestions?
    Apr 2004
    yeah, call the guy that put it in. It could be as simple as a transformer buzzing or as complicated as refrigerant lines touching something. It could be overcharged, it could be....
    I'd kick the guy in the jewels for installing a system in a bedroom anyway.
    Nov 2007
    Jax FL
    Without looking into it a little deeper, in my past experiences the transformer will hum. If it was just installed call the installer and it will be a simple fix. Either way its under warranty.
    "I'd kick the guy in the jewels for installing a system in a bedroom anyway. "
    That is where the existing unit was. This use to be laundary room that was converted to a bed room.
