Results 1 to 2 of 2
    Chill water & hot water in one unit
    Has anyone worked with the Hydronika unit?
    It seems an ideal system for new or retrofit applications.
    Your thoughts please.
    5 ton unit seems large
    for most residential installs. I don't think sticking a mod/con boiler (Munckin) is ver efficent and could cause problems with freezing condensation. I think the Unico unichiller would be better: 3 or 5 ton HP units. When the temps drop to low, switch to a wall hung boiler inside the home.
