    Nov 2007
    Heat pump problem
    After several on and off issues with the power the heat pump when set on heat and you raise temperataure setting the heat pump delivers cool air and cools house down until auxilary heat comes on. Place system for cool and lower the temperature and the heat pump starts heating. Need suggestions and what is wrong.
    You changed your thermostat, now it doesn't work properly.
    Jun 2007
    Metro St. Louis
    See thermostat manual - reversing valve (O/B).
    This isn't a DIY site. Call someone that knows about wiring low voltage HVAC if you don't know yourself.
