Results 14 to 22 of 22
    DC Metro Area (MD)
    A UV lamp might not even be necessary to fix this issue, but a contractor onsite should be able to determine that. Good luck.
    Jun 2007
    Greenville,North Carolina
    Quote Originally Posted by a/c-harris View Post
    its dirty sock syndrome as previously stated
    Bingo both are right clean coil and treat coil,Smell gone.Happy customer.
    Mar 2006
    dirty something, when was the last time the unit was serviced? Clean coils are happy coils, makes sense to me
    Oct 2002
    Quote Originally Posted by acjoe View Post
    I have a service agreement with my HVAC co. - they last came in June (supposed to include cleaning the coils). Should be back next month.
    Quote Originally Posted by BigJon3475 View Post
    Dirty sock syndrome is usually smelled in heating mode. His explination explains it's happening in cooling mode.
    Still seem like dirty sock syndrome?
    It has been in the cooling mode 100% of the times I have encountered it.
    Very thoroughly cleaning the coil may get rid of it for a season, but it usually comes back. Replacing the coil with a coated coil is the only 100% positive way to do away with it permanently.
    RSES Certificate Member
    RSES-SWRA President
    Thanks. I actually forgot to put the question marks behind my sentence since I personally haven't ever dealth with "dirty sock syndrome"
    And I should add "that I am aware of" to the end of the last line of my post.
    RSES-SWRA President
    Sep 2003
    McKinney, TX
    I only know of trane manufacturing a coated coil to permanetly solve the issue. Do other brands also make a coated coil?
    Unless things have changed in the last couple of years, Carrier, Lennox and Rheem/Ruud don't, we just order a new coil and ship it off to get the Technicoat treatment.
    Unless it is a warranty situation, we do the same with Trane coils. The Technicoat process coats everything but the drain pan. In addition to permanently solving the DSS issue, it protects the tube sheet from rusting out, and the copper tubing from formicary corrosion.
    The coated coils from Trane only have the fins coated, so while they solve the DSS issue, there is still potential for the formicary corrosion and rusted tube sheet issues.
    RSES-SWRA President
