Results 1 to 13 of 22
    Oct 2002
    heat pump stinks
    I have a heat pump with the blower in the attic. Recently the weather has been such that the unit will be in the heating mode during the night and the cooling mode during the day. I have noticed that the air coming out of the vents stinks when in cooling mode, but not heating mode. I assume the stink is because the trap is dried out and gungy air is being sucked in through the trap. Why would this not happen, or why would it not be noticeable, while in the heating mode?
    Describe the smell.
    Oct 2002
    Quote Originally Posted by BigJon3475 View Post
    Describe the smell.
    I'll try.
    It is not as putrid as the rotting rat I found in the crawl space last week. I would say it is musty with just a hint of sweetness.
    Florida
    Refrigerant leak? R410?
    dirty sock syndrome.
    Oct 2002
    Quote Originally Posted by deprodigy View Post
    It is R410a. Does it have a smell that might be what I described?
    Apr 2004
    No you wouldnt be smelling the refrigerant.
    If it's got a sweet smell only in cooling mode are you sure there is not a smelly filter attachment or something stuck to the coil you would only smell when it gets wet. Are your filters getting replaced also?
    Sep 2003
    McKinney, TX
    its dirty sock syndrome as previously stated
    DC Metro Area (MD)
    Here's some information on dirty sock syndrome incase you are unaware of what is being discussed Marka: http://www.hannabery.com/dirtysock.shtml
    At this point I'd suggest calling a contractor to check to see if you have this issue and go about treatment.
    Dirty sock syndrome is usually smelled in heating mode. His explination explains it's happening in cooling mode.
    Still seem like dirty sock syndrome?
    Jul 2000
    Northern Wisconsin
    How about it's stinking shoe syndrom?
    My "guess" is that what's happening is that the coil and/or the drain pan is dirty.
    You wet it up and get the "gunk" all slimy during the day during ac mode then dry it out at night in heating mode.
    Next day you start wetting down whatever is there again and for whatever reason it's giving off the smell you're experiencing.
    No matter what it is....... a smell from your ductwork needs to be addressed by cleaning and possibly some form of other remediation. In some instances smells come from molds that are not healthy for the occupants for the home.
    Oct 2002
    Thank you for all the replies, especially the link explaining "dirty sock syndrome". I believe I will contact my HVAC service company (also installed the system) to see if one of those UV devices would be helpful.
