Results 1 to 11 of 11
    Whistling Return Duct
    I recently had an air-conditioning system installed in a house Iím building and have a problem with a whistling noise in the return duct. The installer was notified and his employees attempted to correct the problem by installing an additional, smaller return duct in my office which is located near the larger return. This reduced, but did not eliminate the noise which gets louder if the office door is closed. Some men working on the house overheard the AC dealerís employees discussing installing a baffle inside the main return to quiet the noise by restricting airflow. I believe that this would result in the system having to run longer to attain the same level of heating/cooling which would result in an increase in my heating & cooling costs. Can anyone suggest a solution to this problem? I personally think a bigger main return is the answer, but want to see what other people think
    DC Metro Area (MD)
    What is the tonnage of the HVAC system? It's possible you have an undersized duct system /oversized HVAC system. Was a load calculation done? Adding returns may alleviate the issue a bit, but a balanced and correctly sized HVAC/duct system is needed.
    Nov 2007
    Sherman, TX
    Lack of Return Air
    one of the most common system problems I run into is lack of adequate return air. I frequently run into 3 1/2 to 4 ton systems with a single 14 inch return. You can't have "too much" return air.
    At least once a month, I find a blower wheel in a relatively new system that the center pan has ripped loose from the fins.....almost always caused by inadequate return air ducting.
    Depending on your style of filter/return grill, you might also try bending the fins to a steeper pitch, as return grill fins can restrict the opening as much as 1/3.
    Thanks for the quick reply!! It's a 3-ton system. The dealer stated he would be using Manual J when we talked in his office (I think that's what is used to size systems) and I remember him looking at the bluprints for the house and counting up how many windows faced in each direction. I don't remember what else he may have noted (this was in April). His quote states that "Ducting will be designed according to the standards and specifications found in ACCA (Air Conditioning Contractors of America) manual D, G, & T".
    Nov 2007
    Sherman, TX
    at the risk of being pilloried
    Sometimes, I fear that too many folks get so wrapped up in "calculations", that common sense and experience get lost in the shuffle.
    Keep in mind, that many of us have service jobs in the field, because somebody's "calculations" didn't work in real-life application.
    DC Metro Area (MD)
    JohnPlenge,
    What is your return air setup? Small/Large returns on each floor, etc. From what you say about the door being closed or opened along with the whisting, it sounds like an imbalanced and/or undersized duct system. You should consider having the contractor over to listen to it himself. Remember, duct systems aren't going to be silent (I'm not sure if this is your first experience with forced air systems; I doubt it).
    Quote Originally Posted by JohnPlenge View Post
    Your on the right track if they can do what they state!!!!
    Calculation ,done correctly ,works every time!!!
    Jun 2000
    WYO
    A whistling sound can be caused by a simple reed effect from a blower door not sealing right from a properly sized system. Undersized return can make it worse tho. Is your filter dirty?
    never say never
    Jun 2007
    Metro St. Louis
    Hehe... mine's silent (at least on first stage). The only way I can tell if it's running is if I hear the vibration of the heat pump itself. And if I can get rid of that....
    I'll know more after tonight when the system will have to run in second stage quite a bit (low of 25* tonight). I expect to hear some airflow - but only noticable in the dead of the night.
    Oct 2007
    Sounds like he did it right but I suppose that all could have been to impress you and get the job, I hope not.
    Thanks everyone for the replies. Iíll try to answer all your questions in my reply. The original return air setup consists of a large return duct near the guest bedroom doorway and a smaller return in the master bedroom (on the opposite side of the house). When I complained about the whistling, a third return was installed inside the office which is next to the guest bedrooms.
    This isnít my first experience with a forced air system, but Iíve never heard this sound before in any house. This is my first experience with a return system of this type consisting of one or more ducts carrying air back to the unit. All the others Iíve dealt with had what I would guess is the older way of doing things Ė the unit in a small closet with two rectangular openings in the bottom of the wall to allow return air to flow to the unit.
    Can someone tell me a good way to check the seal on the blower door? I guess feeling for leaking air would work. Iím cleaning the filter every 2-3 days while the house is being finished so that shouldnít be a problem. I hope he wasnít simply trying to impress me, he came very highly recommended by several coworkers.
    I am concerned about the baffle one of the construction workers overheard the installer talking about. This sounds like something that would be placed inside the return duct to eliminate the sound by restricting airflow. Iím concerned that this would reduce the efficiency of the system by making it run longer to achieve the same level of heating/cooling and might cause premature wear by making the system work harder. Can someone give me some information on this?
