+ Reply to Thread
Results 1 to 9 of 9
Thread: Carrier open rtu controller
    Jan 2013
    Batavia, New York
    A Trane voyager with tracker system was removed and a Carrier rtu installed with an open rtu controller capable of using 4 different protocols to communicate with the tracker. It came configured for Bacnet @ 17600 baud rate. Couldn't get comm established, tried 9600 baud no luck. Any ideas what I'm missing?
    Jan 2011
    Bartlesville, Ok
    I believe the Trane Trackers use Lon. And the Trackers frontends I have seen appear to use screen sets specific to their own control boards and points.
    Jan 2013
    Batavia, New York
    That's what I thought too but had no luck with Lon either.
    Jun 2009
    StL, MO
    Those boards need an option card to do Lon.
    UA LU 562
    Dec 2006
    Washington, DC
    Trane Tracker talks Trane Comm3/Comm4 to the RTU. You will not talk to a Carrier Open RTU. Your only option is to add the RTU card to the Tracker panel. This will allow R,G,Y,W to the RTU.
    Quote Originally Posted by Qui-Gon Jinn (Star Wars Episode 1)
    "The ablilty to speak does not make you intelligent!"
    SE Pennsylvania
    Dont know what version of Tracker you have but this may answer your question, page 22.
    https://www.trane.com/Commercial/Upl...rc010_0618.pdf
    Mar 2012
    Hamilton Ontario
    Lon-oc is the carrier card
    Jan 2013
    Batavia, New York
    Thanks for the feedback guys, I was finally put in touch with Mr. Sawyer at Trane controls division who told me the older version of tracker won't communicate with the carrier open no matter what you do. A zn517 or tcm mounted in unit is the only solution. But I saved the best for last while checking out( national acct) the guy at EMS who monitors the Hvacr told me there is a work order in the system to replace all existing controls!! Thought they should have done that when rtu was replaced......
    Mar 2012
    Hamilton Ontario
    Believe the open controller is bypassed if you use to thermostat terminals and you will lose some function (econimizer)
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
