    Oct 2007
    Question on condensate traps
    What is the difference, if any, between the two different kinds of traps on on condensate drain lines--the one which is like the drain under the sink or the one which is elongated.
    Also, which comes first, I can't remember, the "T" or the "P?"
    Thanks.
    Nov 2007
    Sherman, TX
    P traps and R traps
    The two traps that I'm most familar with, are the traditional P trap (like the one under the sink) and the R trap, which looks like a straight pipe with a squiggle.
    I try to avoid the R trap, as they tend to lose their seal unless they're perfectly level..........causing water hammer noises on air handler systems where the coil and drain are on the suction side of the blower.
    Oct 2007
    John,
    Thanks. That helps me.
    San Antonio
