Results 1 to 2 of 2
    Nov 2007
    Question Carrier heat pump factory charge ?
    Hi there,
    My question is a bit DYI but I know it's not welcome here. I got a HVAC guy that will finalize my installation but he didn't know Carrier(he is doing commercial stuff , never installed a carrier residential)
    the combo is a 40QNC018 with a 38QRF018 heat pump
    I have done the house myself but I let the HVAC finalize the installation
    wiring has been pre-wire by a qualified electrician
    refregerant line (5/8 and 3/8 lines) have been pass thru wall by myself 50f of 5/8, 50f of 3/8
    got both service manual to give it to my HVAC man who will connect the hosing
    I might need another manual because the wall unit manual specify a 6lbs precharged (I tought the precharged was into the exterior unit????)
    there also a note the factory charge is based on 25ft of interconnecting line
    does that mean I have a total of 100ft and he will need to add gas ? if yes, will he be able to calculate what he need or he need a specific chart from carrier ?
    here is both service manual I have :
    http://www.xpedio.carrier.com/idc/gr...t/40qn-8si.pdf
    and
    http://www.docs.hvacpartners.com/idc...LBUJ9dQ1A0vet2
    the purpose of all this isn't a DYI, I just want to give everything my hvac man will need to complete the installation because he never done a carrier residential install. I want to be sure he will have everything to do a perfect job.
    I've already call authorized carrier installer and none of them wanted to install that because I already own the unit (bought it from carrier directly)
    Jun 2001
    Louisville, KY
    Uh, ya sure.
    Your hvac guy can find the answer.
    Thread closed.
