Results 1 to 7 of 7
    Apr 2005
    AC requirements to Home Addition
    Okay, a friend has built an addition to his home...a 24' x 30' family room area.
    The temptation is to simply tee off the existing duct work from the existing house, and extending it to two boots/registers in the new space.
    ...I got a feeling this should be thought out a bit more. I am thinking:
    1) find out how much heat/cooling is required in the new space.
    2) figure out the air flow reqs (ie CFM)
    3) find out if the existing furnace/AC system has the heating/cooling capacity, and if the supply fan has the 'oomph' to make it out there.
    Any comments, suggestions?
    Thanks.
    in my lumpy chair
    the only advice anyone here can give you is to call a pro. there are to many variables to tell you if the system can handle the new addition.
    if the system is correctly sized for the original home? it would most likly be undersized for the new addition
    I dont warranty Tinkeritus
    PA/DE area
    I agree with a PRO,system sized for existing home ,ductwork and thermostat location.many people think ductwork is like a garden hose ,you can hack in to it and get water out the end
    It's NOT the BRAND,it's the company that installs it!!!!!
    Apr 2005
    ...I wonder how the PROs would approach it.
    in my lumpy chair
    Quote Originally Posted by the_dude View Post
    with the mannual j,and d calculations
    Tn.
    Quote Originally Posted by lolson View Post
    like lolson said call a heat and cool co. please dont waste your time or money doing it yourself and then it dont work right.
    PA/DE area
    If you do it your self,rough a wire for a window unit and another for electric baseboard
