Thread: Is Rheem Fully Modulated??
11-03-2007, 08:19 PM #1
- Nov 2007
- 71
I've decided on our new Furnace and AC and have what I think is an excellent service company to install it. I was understanding the Rheem is "fully modulated", running from 30% to 100% in 5% increments. However, reading some of the brochures, how the furnace modulates may depend on the type of thermostat you have? Thus, the system may only function as a two or perhaps three stage unit? I don't have a model number. The quote only ID's a 100k btu Modulated Furnace. The brochure shows a "Classic 90 Plus Modulating Gas Furnace". Do I need to further clarify with the dealer what system I'm getting, or are all Rheem Modulating furnaces "FULLY" modulated when using a proper thermostat? Is there a particular thermostat I need to be sure I get? Thanks for your thoughts!!
11-03-2007, 08:26 PM #2
You need Rheem's mod thermostat for the furnace to truly modulate. With a standard thermostat the furnace operates in stages.
11-03-2007, 08:29 PM #3
- Nov 2007
- 71
Thanks. The quote shows a "Rheem Modulating Thermostat". I understand it is some kind of touch screen unit. Does that sound like what I want?
11-03-2007, 08:39 PM #4
With the Mod stat, the gas valve steps in 5% increments from 40% to 100% of capacity. The variable speed blower varies to maintain around 65° temp rise in all firing rates. This is the blue touchscreen stat. With a conventional stat, it stages at 40%, 65% and 100% based on time (and temp with a 2 stage stat) .
11-03-2007, 08:46 PM #5
- Nov 2007
- 71
Thanks!!
