Page 1 of 4 1234 LastLast
Results 1 to 13 of 44
    Nov 2007
    Carbon Monoxide from Natural Gas?
    Hello,
    Forgive me if this is the wrong place to post this question, I'm just looking for a little guidance.
    A few months back (May or June I'd say) I bought a combination natural gas/carbon monoxide detector. At first the carbon monoxide peak level was zero, but then it jumped to 12 and has slowly risen until it now resides at 31. The current reading always says 0 whenever I take a glance at it, but the peak level is concerning me. I've reset it a couple of times to see if it was a faulty reading, but it goes back up within a few days.
    What really has me scratching my head is that we only have electrical appliances in the house. Nothing is running off gas except our heating, which does use natural gas. Even though the heat was not running the whole time the levels have been going up, I'm wondering if somehow that is the cause. If that's not it, what else should I be looking at?
    Any help or direction would be greatly appreciated.
    Thanks,
    Matt
    Myrtle Beach, SC
    I would have a tech measure the CO levels at the furnace. Also, you may want to get another CO detector for your house.
    CO is nothing to take lightly. You may just have a bad detector, or your furnace could be defective, which could make you sick or dead.
    Good luck
    Remember, Air Conditioning begins with AIR.
    is the garage attached ?
    Expect nothing, yet expect the unexpected.
    Press on Regardless, Endeavor to Persevere.
    Nov 2007
    Quote Originally Posted by Kevin O'Neill View Post
    An additional one, or one to replace what I have (a Kidde)?
    Quote Originally Posted by Snoring Beagle View Post
    No garage.
    Thanks for your replies.
    Dec 2000
    Michigan
    Co
    Where is the CO detector located; upstairs first floor or basement?
    What type of hot water heater do you have? Is it next to the furnace?
    What type of clothes dryer do you have and where is it located?
    To test the unit you can put it outside for a day or two and check the reading.
    The quality of my performance, sometimes depends on the quality of my audience.
    Imitation (Plagiarism) is the best compliment one can get -- "Open A Window"
    To improve Indoor Air Quality: Control Indoor Air QUANTITY = "I.A.Q.Q."
    Central Kentucky
    Would be a good idea to find someone in your area who has been trained to do CO/combustion diagnostics.
    Testing the air in the home is not enough to identify the source the furnace will need to have it's flue gas tested for best diagnostic results.
    The problem could be coming from a neighbors home depending on how close they are to you.
    That CO alarm isn't giving you the protection you think it is.
    It is allowed to be exposed up to 70 PPM of CO for four hours before it could alarm and that is no guarantee.
    The only CO monitors that offer any low level protection from CO are the NSI 3000 from NCI www.nationalcomfortinstitute.com and the CO Experts monitor www.coexperts.com
    Be sure to get this situation remedied as quickly as you can.
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
    Nov 2007
    Quote Originally Posted by Xavier View Post
    It's a one level house. I've located it in the living room at this point.
    Probably not what you're asking, but the water heater is an Envi-ro-temp and the dryer is a GE. They are both located in a laundry room on the opposite end of the house from the furnace. Is it possible for either of these to cause a CO problem if they are running off of electricity?
    What should I be looking for here? A zero reading?
    Oct 2007
    Quote Originally Posted by lotr13 View Post
    Hi matt,
    31 ppm is too high! I would recommend investing in a low level carbon monoxide detector. This way it will actually sound an alarm at these unsafe levels of CO. But even more importantly find someone in your area who is qualified to find the source of the CO and eliminate it.
    USA, Midwest
    CO from natural gas? Not unless you're cooking!
    Lotr13
    Forgive me for jumping in, but there could be a number of reasons your CO detector is peaking at 31ppm.
    Most likely it's chocolate chip cookies or a cake or corn bread if you have a gas oven. Or, it could be hair spray, alcohol, PAM cooking spray; any number of other aerosols may affect your detector.
    If you have a standard residential gas oven, it could emit anywhere from 10 to 800 ppm and still be considered safe by ANSI manufacturing standards. That CO level is NOT safe for prolonged exposure, but you would be surprised how much CO comes from a regular oven. Stove top burners also produce CO if the flame tips hit the cold metal of a frying pan or pot.
    If you don't have a gas oven, or haven't used the oven or stove top burners, then the possibility of a periodic backdraft down your water heater draft diverter is the next place I'd look. There's always a chance of backdraft if you run your clothes dryer (gas or electric) with all the windows closed in a tight, energy efficient home. Eventually, the air that should have gone up the flue gets re-burned by the water heater and then pulled back down the draft diverter. That will cause CO.
    By the way, a natural gas flame with clear blue tips doesn't emit measureable CO, unless there's already CO in the gas supply (which is done by some of the natural gas suppliers.)
    Let us know what you discover.
    MN
    From what I gather from your post ALL appliances except for the furnace are electric not gas, no attatched garage, so that means the source for the CO has to be the furnace (unless you smoke in the home, or burn lots of candles) Either way tomorrow morning call a service tech out to do a annual cleaning/tune up on your furnace, it can save your life and those you love.
    You can't fix stupid
    Nov 2007
    Austin Texas
    Carbon Monoxcide Detectors
    Not all Carbon Monoxide Detectors are created equal. I have a TP7 with digital wireless Printout. For $565.00, and a Factory calibration required yearly. I trust it when it says 0 PPM (most of the time in PM checks ive performed in the last 6 months) and I trust it the same when it says 400PPM (once in 6 months - The exchanger had a dime size hole in the top rung of the 4 tube exchanger)...Peak or Avg - It better work!
    12000 PPM will kill you in 1-3 minutes - even if you are awake! Scary huh?
    Do yourself a favor and have peace of mind - Get a second opinion. Even if the 1st opinion came from your own CO tester...
    USA, Midwest
    Quote Originally Posted by DavidInAustin View Post
    DavidInAustin,
    I'm not clear on where the carbon monoxide you're reading is coming from.
    If there's a dime-size hole in a tube style heat exchanger, how does that produce CO? Or, maybe a better question, if the burner is producing CO, how does it get out of the heat exchanger?
    Wouldn't the draft-inducer "suck" air into a hole in a tube style heat exchanger?
    Gus
    Nov 2007
    Austin Texas
    Co
    Excellent question my friend Gus - Venturi effect... (The blower motor is far stronger/powerful air displacing/moving effect than the inducer motor). Venturi effect will pull some CO from the tube ( more or less effected by location of hole in respect to cross airflow) as the air from the blower passes by the exchanger at 1000 - 2000 CFM - if it has a leak.
    If your not familar with "Venturi" - Picture a glass of water with a straw in the glass. If you stick the straw near your lips and blow hard across the straw tip - the water will lift from the glass through the straw and move upwards. If enough cross air is produced - the water will come out of the top of the straw.
    In earlyer times - One would remove the burner assy - wet the hand - stick your hand in each exchanger as the blower was running - If your hand felt cooler in one exchanger compared to the ajoining exchanger - bingo...theres a leak (Note: A very small leak can be detected this way, even today!!) - also Venturi effect!
