Results 1 to 7 of 7
    Tucson
    Control for residential system via internet
    Does anybody know of a control that will allow access via the internet using an existing cable modem for an existing residential heat pump? I am aware of the Infinity/Evolution control with the satellite internet connection but I was wondering if anybody else had a system control for an existing system that could be accessed via the internet?
    Jun 2001
    DFW
    might be what you are looking for?
    http://www.smarthome.com/3054.html
    Tucson
    thanks
    Thank you Paul this is exactly the type of control I was looking for. Do you have any experience with this control? If so is it used friendly and dependable?
    Jun 2006
    internet?
    $300 for what?
    You can get 3 thermostats for that price.
    I wonder if you could explain what the internet does for you? I couldn't see anything compelling about it.
    Massachusetts
    Carrier/Bryant equipment can be controlled via internet connection. Even better, the installing dealer and monitor your system and address any problems noted, sometimes even before you know there's a problem. This is cutting edge stuff and yes, you need their equipment to make it work. Sorry 'bout that.
    HVAC Savings estimator
    I am looking for some sort of HVAC savings estimator or calculator.
    Currently a 1999 home approx 2650 sq feet in ga. 2- 2 ton units I believe are around 13 seer, furnace is running I think about 80% efficient.
    Want to change a downstairs unit to a Trane 16i heat pump with an xv80 furnace. I have come across
    http://www.hvacopcost.com/
    but am not having any luck with it since it doesnt want to give me good numbers from a furnace to a heat pump.
    Jun 2001
    DFW
    Quote Originally Posted by acbobburk View Post
    I have no experience at all with this control. smarthome is a fairly well known company and I have run across references to them several times in other building forums.
    good luck!
