    Jan 2003
    modulation vs dual stage
    So I need to replace my 17 year old coleman furnace. My longtime hvac man has recommended a tempstar 2 stage variable vs 90 with a 13 seer heat pump,75000 btu,with 3 ton heat pump. I want to be as fuel efficient as possible going forward into higher and higher fuel costs.
    Does it make any sense to consider a modulating furnace for this hybrid application. My guy is a tempstar man and they dont carry a modulating furnace as I understand it. Is using a modulating furnace on a hybrid system gilding the lily? Are the systems so new as to be especially problematic?
    If choosing a modulating furnace,is it best to go with a Rheem(longest track record) or a Carrier Infinity.
    Thanks,
    kydoc
    Mar 2006
    The South
    kydoc
    I take by your handle and picture that you live in Kentucky which has reasonable electric rates. Correct?
    Generally speaking, I think the mod furnaces are better suited to areas/climates that have long harsh winters and where electric rates prohibit the economical use of heat pumps either standing alone or in a dual fuel system.
    While I don't know much about Tempstar, I think you are on the right track as far as dual fuel. I would upgrade the heat pump model to one that has a minimum 14-15 SEER and 8.5-9 HSPF eff rating.
    You will need at least some type of filter for IAQ and protection of blower motor.
    I would want to know that dealer has experience with dual fuel applications.
    Good and properly sized HVAC, good install, and a good ductwork system and you should have a great system.
    IMO
    Jan 2003
    ky electric rates
    I just called Duke energy and they say I am currently paying 7 cents per kw-hr. for electric in northern ky.
    THanks,
    kydoc
    Dec 2006
    Middle Tennessee
    if you can afford it, for the best efficiency and comfort set-up go with dual fuel,
    otherwise, i would recommend a heat pump for best efficiency!
    For comfort over efficiency, go with the gas furnace!
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by kydoc View Post
    THanks,
    kydoc
    That's dirt cheap.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by gary_g View Post
    That's dirt cheap.
    hydropower!
