Results 1 to 13 of 18
Thread: what air filter
    Jun 2007
    louisville ky
    what air filter
    what air filter does everyone use on there furnace?
    Infinity Air Purifier, on our Heat Pump Air Handler.
    I think most here would say a 4 or 5" thick,Merv 8 or 10,pleated media filter is a great choice,and the minimum to keep the equipment clean.
    Jun 2007
    Metro St. Louis
    Lennox HC16 - MERV 16 media
    Also considered the Aprilaire ones...
    Jun 2007
    louisville ky
    i have been using the 3m 1500. i know a lot of people on here dont like them that is why im asking. i have looked at lowes all they hay is 3m and the cheap blue one were do you all get them from? my furnace uses the one inch thick ones.
    Rochester, MN
    I have the Honeywell MERV 12 4" media on mine.
    I notice that Lowes don't have a good choice of filters, Home Depot has the good basic Pleated filter in a 3pk for about $6, MERV 8. Anything higher than that like the 3M is hard on your equipment.
    Quote Originally Posted by chrism9232 View Post
    Call your local HVAC contractor.
    Apr 2004
    I use a disposable fiberglass filter. We also use a vaccuum cleaner around the house once in a while.
    Jun 2007
    Metro St. Louis
    Anything other than 1" will likely require some sheet metal modifications. Like Dash said, call a contractor. There are lots of choices in 4 and 5" models. Some of which can be bought at HD/Lowes (I think I saw an Air Bear there once). You can always buy replacement filters online for almost any brand. But you gotta get the unit installed.
    Mar 2002
    Concord, CA
    Why do those people not like them? As far as I know, they'll restrict airflow and reduce system efficiency just as well as other expensive filters designed to make the hardware store profits.
    If all you have is a single medium to small sized filter serving the system then it's likely that you don't have enough surface area to properly support a high efficiency filter. It presents more restriction than the system is designed to handle. Unfortunately, many systems don't deliver proper airflow even with a non-restrictive filter. They're only made worse by the addition of a 3M or anything like it. In other words, Doc may have been steering you on the right course.
    Consider too that you're not really going to have any great impact on air quality unless you run the furnace blower 24/7 or at the very least on a consistent circulate mode. You'll also need to keep the house closed up all the time. If you're ducts leak a lot and in the wrong places then that impact could be negative rather than positive.
    There are numerous assumptions in my reply regarding your situation, such as the assumption that you're goal is improved air quality. Obviously I could be wrong. Suffice it to say that for most people slapping an expensive filter into a furnace often accomplishes little of what they want and results in other things they didn't expect.
    Houston,Tx.
    Quote Originally Posted by docholiday View Post
    Amen! Brother ditto on both the disposable fiberglass filters and the vacuum cleaner sounds like us here.
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
    2" Practical Pleat for return grille applications work good... www.filterfolks.com
    Oct 2006
    Vallejo, CA
    CleanEffects is great and very user friendly. Excellent warranty and very simple technology to understand how it works.
    Virginia
    does it have one in it now measure it and post the size and brand
