Results 1 to 13 of 20
    Oct 2007
    Mount Gilead, Ohio
    rapid fire unit gas smell
    going to check out a rapid unit tomorrow they say they can smell gas when it comes on.was there 2 weeks ago for the same reason.we adjusted the gas pressure because it only smelled when high fire came on. now im thinking my digital manometer isnt reading the gas pressure correctly or maybe its something else.anyone got any other ideas
    thanks
    Oct 2007
    Mount Gilead, Ohio
    forgot to mention this is a direct fire unit, cant remember off the top of my head what the differential pressure is. Im sure the problem is with the high fire gas pressure because the gas smell comes for just a few seconds when the high fire comes on has anyone ever had a problem using a digital manometer on these. im going to takemy utube tomorrow to check
    thanks
    Oct 2007
    The rainy state
    rapid fire unit
    may i suggest you smoke test the heat exchanger
    Michigan
    How old is the unit if it's over 3 yrs old you may need to clean the burners.
    here's something to check go to high fire and see how much burner lift you
    have. might be time to drill the burner.
    Hope this helps
    Dec 2001
    Southern Tier, NY
    Quote Originally Posted by chilly123 View Post
    there isn't any effin' ....Heat Exchanger ....
    go back to the Resi forum ...
    Dec 2001
    Southern Tier, NY
    Quote Originally Posted by techhead View Post
    Hope this helps
    good post ..
    Oct 2007
    Mount Gilead, Ohio
    thanks guys,
    checked out the unit today. forced high fire, gas pressure screw backed all the way out and carried a 4 foot flame at 5" wc, and tripping high limit. factory pressure rated 9.5, have -2.0" no fire pressure so I need 7.5". Called rapid,they say profile dampers adjusted wrong but magnahelic gauge reads .9,right in the middle of factory rating. going back monday w/ some help. unit is new install. I went to the factory 3 day class but but that is mostly startup procedures not troubleshooting and I dont have much hands on. I have no idea on this. Probably something simple. any ideas
    thanks again
    Dec 2001
    Southern Tier, NY
    gotta go back to design figures ...
    airflow
    delta p across damper
    gas press
    temp rise ...
    the solution ..
    is in them figgers
    Anytown USA
    Quote Originally Posted by slimwoodie View Post
    thats was funny
    Dec 2001
    Southern Tier, NY
    Aaaahh...
    you'll fit in here Fine ...
    Oct 2007
    The rainy state
    you and i are talking about two different types of equipment,one of which is produced locally called rapid fire [ a industrial unit] and no i do not belong in the resi forum
    Dec 2001
    Southern Tier, NY
    [QUOTE=in-trane-ing;1664727]forgot to mention this is a direct fire unit,[QUOTE]
    Chilly 123 ...
    whassat ...???
    Dec 2001
    Southern Tier, NY
    C'mon ... Chilly ..
    give it back ...
    the last Instuctor
    had a melt down ...
    rise above it ...
