Results 1 to 13 of 21
    Oct 2007
    Furnace won't stop running
    Had the heat on the other day and I get home in the afternoon, shut it off from thermostat and it won't quit running. Currently turning it off from breaker box. Any suggestions??? Was thinking the thermostat is bad
    South Jersey
    Chase it down and tackle it.
    South/West of Quebec in the other part of Canada
    Darn old furnaces....They just keep going and going and going and going.
    It's Time To Be Nice To People
    Jul 2002
    Slacking off right now
    it always the thermostats fault.
    the poor stat catches all the blame all the time
    somethings wrong - its the thermostats fault
    hey honey there's no hot water and the bog is plugged
    call a repair man dear - it must be the furnace thermostat!! make sure you tell him you think its the stats fault and ask him to install the one I picked up from homo's
    www.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
    Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
    Gonads serve a useful purpose but are no substitute for brains
    Toledo, Ohio, United States
    Twilli recommends Talking thermostat and it can tell you whats wrong
    http://www.talkingthermostat.com/
    No Heat No Cool You need Action Fast
    Feb 2005
    Barrie, Ontario
    Quote Originally Posted by twilli3967 View Post
    Just what I need... Somebody else nagging me to change the da**ed air filter
    SMO0625... If it seems like you're not gathering a lot of sympathy here, read this link and all will be clear. When it comes down to the nuts and bolts of the equipment, such as why it won't shut off (heat or fan?) and there are a hundred different reasons on a thousand different furnaces, remember safety first and get a professional... and 99% of the time it's not the thermostat... but there is that 1% which gives hope...
    http://hvac-talk.com/vbb/showthread.php?t=1241
    Is this a Fabreze moment? C.Y.D. I'm voting white elephant. 2.
    Victoria,Tx
    Twilli used to be a thermostat
    Jun 2002
    Dacula, GA
    You could have a bad circuit board. It has happened before. Even with no signal to the green wire the fan will stay on.
    Sen. Barry Goldwater
    IN THE CRAWL SPACE
    Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
    Colorado flatland native
    Changing your thermostat when the furnace breaks is like changing your gas petal because the car wont run. Call the man Aunt Bee.
    Walter Matthau
    Nov 2007
    louisville ky
    is it the heat or the fan running! do you have a disconnect on the furnice?
    must be the the thurmostat set at a 45 on the wall. lol! I had the same prob not to long ago and it was the thermostate! It is alot cheaper to replace the t-stat verses the computer.......... does your temperature on the stat read the same as a thermometer? furnace does not know how to kick off if nothing tells it anything. that will be $1000 dollars good day sir! lol!
    newton,mass.
    Quote Originally Posted by J-HITMAN View Post
    I think the problem could be with one of these.
    (A) thurmostat
    (2) thermostate
    (C) t-stat
    (4) stat
    (E) something else
    (6) none of the above
    Good day sir...
    "Nothing else can poison our culture, corrupt our society or ruin the character of our people like unearned money or unearned opportunity." -- James R. Cook
    "Fooling around with alternating current is just a waste of time. Nobody will use it, ever." Thomas Edison, 1889.
    Nov 2005
    Charlotte, N.C.
    Sounds like the wobbling shafts gone bad. Time for a new one.
    If it sounds like we are making fun of your situation, that's a coincidence and we're sorry.
    Call a pro.
    Those who restrain desire do so because theirs is weak enough to be restrained. (William Blake)
