    Nov 2001
    East Texas
    cleveland steamer oven
    honeywell ignition module s87b. It it not firing, it sounds like it is trying for about 5 seconds and then locks out. Ihave replaced the rod and spark wire.
    Cannot see any spark. The flow chart says 2 replace the mod if the fuse is ok...
    chicago suburbs
    google....cleveland steamer.
    FILL OUT YOUR PROFILE!!
    Nov 2001
    East Texas
    Quote Originally Posted by tinner73 View Post
    U r sick..
    Dec 2006
    McMinnville, Tennessee
    Are you
    getting power to 24 input side?If so then I'd pull spark wire off and go towards ground if no spark,or not very hot,replace control.Also look at the ground,
    If you build it they will come,,,they built it and they went.
    Nov 2001
    East Texas
    Its working now, out of alignment...
