Results 1 to 13 of 15
Thread: Leaf blower
    Oct 2007
    Mount Gilead, Ohio
    Leaf blower
    This daggone thing only runs w/ the choke on and thats only about 30 seconds. Probably cheaper to replace than to fix unless anyone knows what the problem may be.
    Toledo, Ohio, United States
    Quote Originally Posted by in-trane-ing View Post
    Twilli thinks you may need some carb cleaner
    No Heat No Cool You need Action Fast
    Oct 2007
    Mount Gilead, Ohio
    will give it a try. had to clean my gutters by hand today,and that was no fun
    thanks
    Twilli used to be small engine repairman
    Oct 2007
    Mount Gilead, Ohio
    Small engines have always been troublesome to me. This year i burnt up my rider and my push mower and now this thing. I tried throwing it across the garage to better mix the oil w/ the gas but still didnt work
    Oct 2007
    Austin Texas
    Some times too much oil in gas and fouls out carb.
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
    Houston,Tx.
    If it runs with the choke on you have a gasket leak somewhere, engine has to have air to run so it's pulling air from somewhere probably a bad gasket.
    Oct 2007
    Mount Gilead, Ohio
    thanks guys, havent had a chance to look at it again but ill check it out again tomorrow.Im sure oil mixture is right, I use stihl oil that comes 1 can per gallon. think ill drain the gas and clean the carb first
    thanks again
    Twilli wants to know because Twilli thinks Mr bill wrong on this one. But should Twilli be wrong he will buy Mr Bill lunch.
    Oct 2007
    Mount Gilead, Ohio
    got home late again, hopefully work on it tomorrow
    burlington county n.j.
    only takes 5 minutes to spray some gumout through the carb.........
    you're keepin us waitin...................
    i have to agree with Twilli on this one, sounds like its not gettin enough fuel.
    Oct 2007
    Mount Gilead, Ohio
    Talking
    Quote Originally Posted by t527ed View Post
    Soorrrrrrrrrrrrryyyyy, havent even made it to the store to get carb cleaner or id go do it now
    Oct 2007
    Mount Gilead, Ohio
    Twilli was right. Sprayed carb cleaner through carb, started right up and is working great
    thanks twilli and everyone else w/ input on this irrelevant question for this site
