Thread: ramsond quick connect fittings
10-30-2007, 07:34 PM #1
New Guest
- Oct 2007
- 3
Hello all,
First post here so go easy on me! I had my hvac guy install a ramsond split a/c system that came precharged. I think he installed it correctly becuase it is "low on pressure" as he puts it. Is that possible that it would come incorrectly charged from the factory? Should it be able to just be hooked up with the quick connect fittings and pressurized via the release valve that is on the brochure? Just trying to figure out if I'm getting taken for some extra cash.
Thanks in advance!
10-30-2007, 07:55 PM #2
- Mar 2007
- West Palm Beach
- 172
I have no experience with these particular units, but a pre-charge does not necessarily mean a full charge, it is quite possible it is low on gas, so you will have to trust in your tech.
10-30-2007, 08:26 PM #3
New Guest
- Oct 2007
- 3
10-30-2007, 08:30 PM #4
New Guest
- Oct 2007
- 3
1. PRECHARGED WITH R410A
ALL RAMSOND MINI SPLIT SYSTEMS ARE PRECHARGED WITH R410 REFRIGERANT. THERE IS NO NEED TO ADD REFRIGERANT.
This comes from Ramsonds website.
10-30-2007, 08:48 PM #5
- Oct 2007
- Mount Gilead, Ohio
- 166
not sure about the Ramsonds but most split systems come precharged for 15' lineset.If lineset is longer the charge needs to be adjusted. Also there should be no charge from your installer as your new system should be operating correctly before he leaves.Thats what you paid for. If installation is not done correctly thats on his dime.
