Results 1 to 11 of 11
    Oct 2007
    Type of Humidifer on a Down Flow
    What are my humidifer options for this type of downflow setup i can only access the Cold air Side. Would a TrueSTEAM be good for this?
    Feb 2007
    Las Vegas,NV
    I didnt know you could use copper piping like that on a gas line. Thats a new one to me!
    burlington county n.j.
    what is your ductwork made of???
    Oct 2007
    Sheet Metal
    hard to tell with out actually being there but there may be enough room to mount a small bypass down on the coil box. that is a V coil so it may be possible.
    getting that blower out looks like it would be a real PITA with that gas pipe in the way..........
    Oct 2007
    There is a door in front of it that swings towards it so i dont know if there would be much room. What about the new truesteams do they need to be on the warm air side? So if i have enough room to mount at the coil the hole would be as close to the floor as possible if its shaped as a V and not a A correct. Would i even want a bypass or flow through style that can leak down in to my furnace?
    have never seen a steam humidifier so i can't comment on that.
    if there is room to mount a small bypass down on the coil cabinet it can't run water down through the heater.
    Oct 2007
    Ok so it looks like i have room to mount the bypass duct on the V Coil So i guess i can go with any type of Humidifer?
    Lincoln, Nebraska
    How many square foot is your house? You could mount a Aprilaire 700 or other brand power humidifier on the return. Make sure they hook it up to hot water. General also makes a mist humidifier that just takes a small hole in the duct and has no drain. Used one once in a pinch and the homeowner loved it.
    Its a good Life!
    Oct 2007
    1700Sq ft i was looking at the powered but they have to be on the supply side. I was looking at theDesert springs (i think there may be a cleaence issuewith the drums) and the aprilair 600 is this a good unit or should i go with the 500. Its a brand new home.
    Lincoln, Nebraska
    Aprilaire says a 700 can be on the return side but must be hooked up with hot water. The 600 is a good unit and is totally automatic and needs a outdoor sensor. The 500 you would need to manually adjust.
    Its a good Life!
