Thread: Advice on Furnace
10-30-2007, 02:41 AM #1
New Guest
- Oct 2007
- 1
Advice on Furnace
I need advice on selecting a furnace.
I finished out the loft above my barn for an in-law suite.
Approx. 500 sq ft (one bed, living room, bath).
Cathedral ceiling - 2x6 construction (r19 insulation) also same r value in
floors. I live in connecticut. Looking to heat with
LP forced air furance, as there is no nat gas in our area
and looking to keep costs/maint down versus heating oil system.
Scientific wild assed guess says I only need about 25,000 btus
for this space. Smallest furnace I can find for inexpensive cost
is 40k input x 80% afue = 32k output.
- Is this still oversized?
- Area will only be used a few months per year (visitng parent), so
looking to keep costs down.
- I can get a Dayton single stage furnace or for about $150 more
I can get a Goodman (Badman?) 2 stage. Thinking about the 2 stg
since the 40/32,000 btu may be too much for my area, at least a
2 stg. on the low stg. would keep longer cycles running.
Any feedback appreciated.
Also, how bad is a Goodman and how good/bad is a Dayton
forced air furn? Keep in mind this isn't for my main house, just
the part-time loft.
11-04-2007, 09:39 AM #2
- Feb 2006
- Tn.
- 1,331
where do you live ? ill install it! Also Im not too big on eithier of those brands but I guess they'll work in this application.
11-04-2007, 09:46 AM #3
Call a pro, have them do a load calc and give you recommendations.
11-04-2007, 09:57 AM #4
in some countries they use the heat from farm animals to keep them warm...im not joking
as far as my in laws? that would be good enough
I dont warranty Tinkeritus
11-04-2007, 11:02 AM #5
Just remember that some Goodman 2 stage won't allow a 2 stage stat. They will time to high after at most 15 minutes. So much for long run periods on low. That's the last furnace you want in an oversized situation!
