Thread: just wondering
    Oct 2007
    Talking just wondering
    over the past few days I hear my unit cut on (as it should) but after it reaches the desired temp., the unit cycles off...after a minute I hear the air start again...then stops...after a minute it starts again...then stops. It does this approximate 7 to 8 times......then goes through its regular cycle again........whats gives??????
    leland nc
    when was the last time it was serviced
    might have a control going bad or a weak blower or just about any thing
    call and have it serviced and have the tech find out why it is happening
    Myrtle Beach, SC
    What kind of unit? Gas, oil, heat pump, AC?
    Where are you?
    More info needed. Vague question gets a vague answer.
    Remember, Air Conditioning begins with AIR.
    need more info but it sounds like an old 70% eff. unit with hellical fan control. i have seen the pilot rust out and the large resulting flame will heat the fan switch turning it on. have your furnace looked at by your local professional.
    Tn.
    . The safest way is to just call a technician. theres too many variables without seeing it in person . good luck
    in my lumpy chair
    every time your blower motor cycles on and off like you say it draws a lot of electricity every time it starts
    call a pro in your area
    I dont warranty Tinkeritus
