+ Reply to Thread
Results 21 to 36 of 36
Thread: How's your brazing?
  1. #21
    Oct 2008
    Royal Palm Beach, FL
    High flush tanks of that type are different. And if I had replied your answer in my Journeyman's or Master Plumbing practical test, I would have failed. Our Plumbing theory/test preparer who had taught in Vocational Schools for years stated that if you replace the flush pipe to THAT type of toilet, with a swan neck flush valve, it won't work properly. He went on to state that if you try to fabricate one because the original one was lost, that it won't work. That it is necked down at the bottom by the ell. Do NOT ever cut it off. I had a customer who's father was an old master plumber in NYC and he gave her one of these toilets as a gift in the new house they built where I worked. All the parts were there.
    It is not a syphon jet toilet. It is a blow down type where the high volume of water causes the bowl to evacuate. The Kohler Knock Off flush tank toilet is not the same as that toilet.
    That toilet may or may not work. If it doesn't flush properly, that's the reason why.
  2. #22
    water powered lights
    Keep it simple to keep it cool!
  3. #23
    Feb 2012
    This must be what they're using for toilet paper:
  4. #24
    Dry as a bone Tucson
    Thats not brazing, more like soldering which is a whole different animal.......................
    "I aint going to spit on 30 years of my life" Monte Walsh
  5. #25
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by Jigjoe View Post
    You know,... he ought to hang some there, as a joke!
  6. #26
    Aug 2009
    Jurupa Valley, CA
    Quote Originally Posted by ACFIXR View Post
    Technically, soldering IS a type of brazing.. just using Solder (Tin/Lead alloy) as the filler material. Brazing is simply any molten metal bonding helped by capillary action.
  7. #27
    Oct 2012
    Kansas
    I dig it. I think that would fall under the steam punk style. Would be kind of cool for a nicer bar bathroom or man cave
    Sent from my iPad using Tapatalk
  8. #28
    anywhere my RV is
    Quote Originally Posted by CraziFuzzy View Post
    actually in the world of welding, the difference is temperature, Generally anything under 600°F is considered soldering, anything over 600°F is considered brazing.....or was it 800°, it's been 30 years since I was a certified welder I can't remember.
    But basically, both soldering and brazing use the same technique....basically.
    Why am I the only naked person at this gender reveal party
  9. #29
    Mar 2013
    Utah
    looks like the copper going to the lights is for show. as you can see how they are mounted to the wall, wire can easily be ran through. but it is cool if i ever have the time i might try something like that but done all bent. that will not be easy but im getting better with my bender.
    Do it once. Do it correct.
  10. #30
    Jan 2013
    florida
    pretty cool though...you have to admit...
  11. #31
    Nov 2013
    Soldering is done at <800f
    Brazing is 800 or above, and below the melting point of the metal
    Welding is fusion done at the melting point of the metal
    Anyway, the style is "steam punk". Think Jules Verne...
    My wife is into, and I'm starting to have some fun with it as well.
    She has actually been accumulating some of the stuff for this style throughout the house... Whatever... I'm not a woodworker, at least I'm comfortable working with metal....
    Chase
  12. #32
    Cool stuff
  13. #33
    Jan 2014
    New England/Florida
    Looks like they are soft soldered not brazed, the shut off valve behind the toilet sure looks like soldered.
  14. #34
    pretty cool, definitely not brazed though, it's soldered
  15. #35
    Mar 2014
    Pittsburgh, Pa
    Thats soldered. Nothings discolored.
  16. #36
    Arizona
    That is cool!
    Still Crazy after all these years.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
