    Pittsburgh
    Confused Sporlan Valve Identification Help
    I know you guys are out there, you know the ones that know every part number and how to decode them. So here it goes, I found a TXV in my truck that I didnt know I had, obiously I dont know the application. The valve body says: IVE 2 and under that RPB.. The powerhead says 43 VGA.. Please help.. Im assuming its a 2 ton but other than that, what does the rest mean ?
    Uncasville,CT
    try this link for the sporlan site
    http://www.sporlan.com/10-9.pdf
    Las Vegas NV
    Quote Originally Posted by coolerguy View Post
    IVE 2 is an 2-ton nominal Sporlan OEM valve that would be replaced by the RIVE series
    Used in A/C and Heat Pump applications
    RPB = Rapid Pressure Balancer for off cycle pressure equalization
    43 VGA = R-22 A/C Power head
