Results 1 to 13 of 33
    Vancouver BC
    Transport Refrigeration Units
    Anyone here work on these units? Just wondering similarities/differences with stationary refrigeration units?( I got up close with a intermodal unit today and it looked fairly interesting to work on?). Do you like working on these units? Weirdest thing you've ever found in a reefer trailer?. thanks.
    Is it fixed yet?
    Well when you consider that in most cases a transport unit will haul loads from -20 degrees F to plus 80 degrees F in ambients from -30 or colder to 100 plus within days while bouncing down a highway at 70mph and keep the temperature of the freight within 1 degree of setpoint there are interesting to work on.
    Oct 2002
    Denali Park, Alaska, McMurdo Station, Antarctica
    transport units
    Mainly my experience is with Carrier transicolds and a couple of Thermoking container units.
    Carriers- damn near bullet proof, course all of them here are the electras so there is no diesel power plant driving it. But they will operate in just about any conditions you can imagine. The over the road units have alot of rubber hoses so they are your main leakage areas or at least have been in the past. Beyond that they seem to hold up pretty well. Kinda like big heat pumps only with more capacity.
    Good luch
    Nov 2005
    so cal
    Quote Originally Posted by yanertrivr View Post
    Good luch
    yanetrivr, do u have pdf files on the carrier tansicolds. i work for carrier kinda and thought of how these could be for the techs and if they are taken care of.
    Oct 2002
    Carrier stuff
    I don't have much for these in PDF but I will look, I can send a couple photos next week, and I'll send whatever I have in pdf at the save time. Just back to work and am still finding stuff after 7 months away. Most of our applications are Electras stuck in the wall of a warehouse, as soon as I get them de winterized i'll send some pics and maybe some of the process also.
    Cheers,
    Yanertrivr
    Vancouver BC
    I guess my real Question is : Why is Transport Refrigeration considered a separate trade in Canada?. What is so different about these units that makes it a whole separate trade?. How easy would it be for a Refrigeration guy to work on one of these units?
    Is it fixed yet?
    Quote Originally Posted by vancouvertech View Post
    The refrigeration side is close but the electrical and diesel engines are different.I don't know about you but I havn't seen too many diesel powered reach in coolers.
    Nov 2005
    so cal
    Quote Originally Posted by Reeferman View Post
    i used to run these around the country but didnt work on them, but i bet thephase shift is been taken care of via an inverter. i bet the module is dc tho. i wouldn't mind the knoledge. ill look it up yanrtrvr ill look it up this suday we got inventory sat morn o/t
    Oct 2002
    Arrow
    These will get you some for containers, but they should have some for the truck units here at this site also, I might have the Thermoking one also. Try these
    www.thermoking.com/tk/index.asp
    http://www.container.carrier.com/det...ETI742,00.html
    Nov 2007
    Syracuse New York
    Greeting fellow HVAC people, i was brosing search engines and came across this forum page, I am a consultant in transport refrigeration equipment and have started a forum page myself. If you want you can drop www.reefertek.com.
    I am looking fo other memebers with TRU expierence and post feedback that may benefit to this sight. as well i will chech in on this sight for postings as well.
    Regards, Reefer-tek
    Austin,Texas
    I spent a year in Afghanistan babysitting a couple hundred of these transport reefers in Kandahar.Thermokings,Carrier,and some Mitsubishi.Tough SOB's.I watched these things make -25C all summer with 115F+temps 6 hours a day.
    Yea we blew a couple dozen condensors but I didn't lose but 6 compressors and some units were 10 years old.Had to wash out the condensors every two weeks.(Dusty)Excellent pretrip program on the newer ones.I am impressed.Most using 134A.
    Nov 2007
    Syracuse New York
    R134a
    Quote Originally Posted by cascader View Post
    No most reefer units are not 134a, actually R404a is real popular refrigerant here for its deep frozen capacity, we use 134a for medium temperature applications and air condition. I would believe considering the high ambient temp conditions over there, in afgan that 404a would only put the equipment to rest permanently. Its normal operating pressures typically operates 200psi abover and over 134a. operating pressures.
    Here is list of refrigerants that were used in TRU equipment and may still be found in tru equipment. r-12, r500, R502, r-22, r401b, r402a, r407c, r404a,and 134a.
    Oct 2002
    Carrier thin line
    The carrier thin lines i am dealing with here are all R134A, with arctic kits so suprise they actually have cch on them, but they have them de-energized during compressor run time< make sense I suppose in warmer climates but???
