Results 1 to 12 of 12
    Oct 2007
    Majestic gas 36DV fireplace
    My Majestic gas fireplace model #36DV-01. valve will not turn to the on position. I can get the pilot lit but the valve will not not turn to the on position.
    May 2005
    Madison, WI
    Call the nearest Majestic dealer and make a service appointment. Valve might be sized up or it could have some sort of safety in it where it wont turn to ON under certain circumstances. I am not familiar with what valves Majestic uses.
    S.E. Pa
    Cool
    Majestic uses Honeywell VS8421 and SIT NOVA 820valves.
    Make sure the glass is off and the on/off switching is 'off'. That way, if there is any delay in ignition, it shouldn't be forceful. Don't hover near the burner. Stay low and a bit to one side until you've proven it lights properly. Once the control knob is in the 'on' position and you call for heat (turn it 'on'), the burner should light within 4 seconds. If not, immediately turn the unit completely off and call for service.
    If the pilot is lit and the knob won't rotate, try pushing in on the control knob a bit then see if it won't rotate counterclockwise. If that doesn't do it, shut it off and wait for a qualified service tech.
    HTH,
    Hearthman
    Feb 2013
    I also have a Majestic Model Gas 36 DV-01. I was able to light the pilot light. But the black on/off switch doesn't cause the flame to come on. Can you tell me what I'm missing??
    Buster
    Dec 2011
    make sure the pilot/on/off knob is in the on position then try the on/off switch
    Feb 2013
    Turning on magestic model gas DV-01
    Quote Originally Posted by darthvader View Post
    Thanks Darth I did that and still no luck. After I got the pilot to light I moved the green knob back so that "on" is facing the silver post at the bottom.
    Then I tried to light the fireplace by turning the black power switch on - no luck....
    Appreciate the help!
    Dec 2011
    push the knob in a little and make sure its turn completely counter-clockwise. if it is turned as far as it can. there isn't much more I can tell you as this isn't a DiY site, and anything more is pretty involved, but its sounds like it might be a bad connection at the switch.
    Feb 2013
    Thanks Darth
    Thank you Darth, I honor you for your help. Unfortunately it didn't work, so will have to round up service call. The problem here in Conn is massive blizzard and the main heating picked today to go out
    Oct 2010
    Toronto
    Replace your wire connectors at both ends (if applicable) at the gas valve & on/off switch.
    Test your switch, .1 or .2 ohms is a good switch.
    Feb 2016
    I have this fireplace and the glass got broken. Does anyone know the dimensions on the glass that fits in in the unit? Anyone still have the owners manual and can help me out? Thank y ou.
    S.E. Pa
    You cannot get a local glass company to replace it. Contact the mfr. through Monessen Hearth Systems to get a factory approved glass with the gaskets. This is either tempered or ceramic glass. Using the wrong glass can cause all sorts of problems ranging from escape of deadly carbon monoxide and soot particulates to increased risk of shattering such as from a delayed ignition to overheating of nearby combustibles since the glass has a major impact on heat transfer and thus temperatures of surrounding combustibles. hth
    Nov 2009
    Simcoe, ON Canada
    Can you check the exact model number. Majestic made a lot of direct vent 36's but have not seen a manual for a 36DV. I have seen a DV36.
