Results 1 to 7 of 7
    Long Island, NY
    what kind of furnace?
    I just moved in a house, and I am wondering what type furnace I have...It is believed to be original to the structure, which is 36 years old. I can take some pictures of it. It works well, but it is outdated- Has no hot water storage tank, no name I can see on the side panels, and it is in a utility closet in my kitchen. The only thing I see happening is the hot water pressure is about 60% less than the cold. Also, if you take even a reasonably long shower, you run out of hot water. Any ideas on what may be wrong? And what type furnace this is? I can take pictures if nec.
    TIA
    Take pics.....
    Sounds like some kind of boiler with a "tankless coil" which is a coil sitting in the boiler's hot water which in turn heats the domestic water.
    Long Island, NY
    OK- I will put up some lights and take some good pictures....Barring OT today, I should be able to post them tonight..Thanks so far guys!
    Toledo, Ohio, United States
    Twilli say Coleman....Twilli used to be Carnack
    No Heat No Cool You need Action Fast
    Long Island, NY
    Confused
    OK- This is the first chance I've had to get on here since last..The burner itself is a Beckett...The main boiler cabinet is green.. Pictures still pending.
    A quick question, there is a "delayed ignition" condition happening now. We had a tune and maintenance cleaning done Oct. 9th. Wasn't doing this until just 5 days ago. The burner starts (begins spinning?), then the thing doesn't ignite a flame until a second or 3 afterward. Sort of like a stutter. What is happening, I don't know these things well.
    Thanks in advance
    Long Island, NY
    and by the way Twilli, ....What???
